construction hand tools
A hand tool is a device for performing work on a materialor a physical system using only hands. The hand tools can be manually used employing force, or electrically powered, using electrical current. Virtually every type of tool can be a hand tool and many have also been adapted as power tools, which get their motive power from motors or engines rather than from human mechanical action.
Portable electric power tools are designed for a widevariety of uses including construction, tree cutting, bridging, or tree clearing. Electric power tools increase production and reduce time and manpower. Although there are many varieties of electric power tools.
Important information about tools:
We, GROOK Team tried to collect all construction hand tools in one Excel sheet to help other to know more about tools and what each tool used for, also it’s helpful for request for quotation (RFQ) or send offers.
Excel sheet contain following tools (More than 150 items):
Screw driver, Nut spinner, Wood-Chisel, Voltage-Tester, Linesman-s-Pliers, Pliers, Concrete-Pincers, Cable-Cutter, Ratchet-Wrench, Heavy-Duty-Pipe-Wrench, Drive-Ratchet, Adjustable-Wrench, Bolt cutter, L-Wrench-With-Screwdriver, 4-way lug or Cross-Rim-Wrench, Hexagon socket key, Hex-Key-Wrench, C Clamp locking, Utility knife, Steel saw, Hammer, Cold Chisel with Grip, Solid Head Rubber Hammer, Steel-Tool-Box, Plastic-Tool-Box, Bolts-and-Nuts, Nuts, Eye Screw, Hook Assortments, Adhesive Tape, Adhesive Aluminum-Tape, Adhesive Carton sealing tape, Adhesive Cloth Tape, Glue, Washer, Plastering Mesh (roll), Welded wire mesh, Plastering Mesh (board), Galvanized barbed wire, Angle bead, Head-Pan, Paint-Roller, Roller Sleeve, Paint-Brushes, Roller Frame, Sand or glass paper, Putty-Knives, Bricklaying-Trowel, Plastering-Trowels, Tiling & mastic trowels, Plastic float, Poly Sponge Float Fine, Cleaning Sponge, Bucket, Polythene Sheeting, Tarpaulins, Shovel, Soil rake, pickaxe, Steel Hatchet, Wrecking bar, Chalk line, Heavy-Duty-Bench-Vice, Measuring-Tape, Tape-Measure, Spirit-Level, Tri square, Caliper, PVC-Clear-Level-Hose, Draper Tools Digital Multi-Meter, Wheelbarrow, Air-and-Water-Hose, Hose-Clamp , Electric-pump-hose , Cable reels , Socket extension , Electrical Wire , Nylon-Rope , Nylon Lines , Cup Suction Plate , Wire-Brush , Plastic concrete spacer , steel-Rod-Bar-Wire , wire-rod , Soldering-Iron , Caulking-Guns , Foam-Gun , PPR-Welding , Testing-Pump , Hand air blower , Bottle Jacks , Garage Jack , Caster-with-Brake , Stepladder , Door-hinges , Door lock , padlocks , Chain , Chain-Hoist , Aluminum-Tripod , Tile Cutter , Tile Spacers , Welding machine , Welding rod or heat sealing , Welding face mask , Hand cutting torch , Welding hose , Acetylene Regulator , Drill-Bit , Wood-Auger-Bits , Paint Mixer , Hole-Saw , Slotting-Cutter , Flat-Cut-Off-Wheel , diamond for surface preparation , Work Light , Ceramic cleaner , Greases , Wheelie-Bins , Plastic Bins , Brush ware , Drywall Cart , Hand Truck or Hannibal lectern, two wheeler, stack truck, dolly, trolley, trolley truck, sack barrow, sack truck, or bag barrow , Shopping-Cart (trolley, carriage) , Weighing scale , Torch , EYE PROTECTION-SAFETY BELTS, SAFETY STRAPS, SAFETY SHOES AND SAFETY JACKETS-HELMETS , Safety equipment , Warning tape or Caution tape , Traffic Cones , Work gloves , Construction Boots , Dust Sheets , Chain-Saw , Drill , Grinder, Rotary hammer, Jig saw, Circular saw, Plate Compactor, Double-Drum-Vibratory-Roller, Power-Trowel or power float", "helicopter" or "trowel, Vibrator, Generator, Water pump, Cement (Concrete)-Mixer.
Attachment | Size |
![]() | 1.36 MB |
