This includes:
1-Relationship between tasks
2-Setting Links
Tasks are linked to each other by any of the following four relationships.
Finish to Start – means for two tasks A and B, B can start only after A finishes. Eg. Walls can be built only after foundations are over.
Start to Start – means B can start only after A has started. E.g. if task A refers to a friend getting paint and Task B refers to you painting the wall, then you can start painting the wall, once the activity of getting paints has started.
Finish to Finish – means B can finish only after a has finished. E.g. only after procuring of paints is over, can the task of painting the walls be over.
Start to Finish – means B can finish only after A has started. E.g if in a relay race, if Task A is the 2nd racer starting to run and Task B is the 1st racer finishing his race, then it is a start to finish relationship. Start to finish relationships are the most uncommon.
Microsoft Project Tutorial - GROOK network
Attachment | Size |
![]() | 35.31 KB |
