The X-Seed 4000 : the tallest building ever fully envisioned- Height 4 Km
General information
Location Tokyo, Japan
Height (m) 4000
Height (ft) 13,123
Number Of  Floors 800
floor capacity 500,000 and 1,000,000 people
Cost 324 billion USD–972 billion USD
Status Vision
The X-Seed 4000 is the tallest building ever fully envisioned, meaning that the designs for construction have been completed. The idea was initially created and developed by Peter Neville.
Its proposed 4 km (2.485 miles) height, 6 km (3.728 miles) wide sea-base, and 800 floor capacity could accommodate five hundred thousand to one million inhabitants.
It was designed for Tokyo, Japan by the Taisei Corporation in 1995 as a futuristic environment combining ultra-modern living and interaction with nature.
Unlike conventional skyscrapers, the X-Seed 4000 would be required to actively protect its occupants from considerable air pressure gradations and weather fluctuations along its massive elevation. Its design calls for the use of solar power to maintain internal environmental conditions. Also, the proposed area is situated on The Pacific Ring of Fire, which is the most active volcano range in the world so X-Seed 4000 would be subject to tsunamis and earthquakes. The Shimizu Mega-City Pyramid (also planned for Tokyo, Japan) faces the same problems.
A sea-based location and a Mount Fuji shape are some of this building's other major design features — the real Mount Fuji is land-based and is 3776 m (1.725 miles) high, nearly 224 m shorter than X-Seed 4000. The X-Seed 4000 is projected to be twice the height of the Shimizu Mega-City Pyramid at 2004 m. Other projects that may be in the top five man made structures are the Dubai City Tower (2400 m) and the Bionic Tower (1128 m) in either Hong Kong or Shanghai. These structures will be in Asia.
Some estimate that the cost to construct the X-Seed 4000 structure may be somewhere between US$300–900 billion, in 2006 dollars ($324 billion–$972 billion in 2010).
References : http://www.geekologie.com ,  www..wikipedia.org
