Tip 1 – It is best to think of an interview as a two-way discussion. Yes, often a stressful discussion but remember not only are they checking you out, you are checking them out. In fact, one of the most important actions you can take to prepare for an upcoming interview is to research the company. It is easier than ever to get on the internet, enter a search word and come up with relevant information. In fact most companies have a web page of their own where you can read up on company history and recent press releases. Be thinking about questions you can ask during the interview as well. Make relevant observations about what is going on with the company and ask your interviewer to comment. You may also want to consider asking some questions like the following.
1. Is this a newly created position?
2. What do you think is the most important thing for a new hire to understand about this position? This company? Or this department?
3. Why did the previous person leave this position?
4. What do you think will be the biggest challenge for the new hire?
Tip 2 – Another good way to prepare for the interview is to put together 3-5 well thought out power stories and a couple lessons learned stories. I use the term power stories to define your stories that tell of times you solved problems on the job. These stories are very important to think about in advance of the interview for responses to behavioral interviewing questions which are used very often by skilled interviewers. These types of questions ask for you to describe times in the past when you solved this or that type of problem. A good format for the stories is to describe the problem, describe the action you took, then describe the result. This is called the PAR technique for Problem, Action, Result. Once you write these stories out, list in the margin the characteristics these stories demonstrate. Then you have ready answers for some questions like “Tell me about a time when _____?” or “What is your biggest strength and why?” Don’t forget to rehearse your answers out loud. It is best to have someone ask you the questions to make the practice more realistic.
Tip 3 – One often overlooked key to good interviewing to have clear starts and stops to your questions and answers. This helps to set a good rhythm for the discussion. It also demonstrates your ability to be concise and listen to others. Don’t be afraid of a few seconds of silence after you finish your answer. A good interviewer will use silence as a tool to get you to rattle on about stuff you did not intend to reveal. Also, silence is an important tool for you to learn use as well, especially come negotiation time.
source: careertipsblog
