Millions of men in the United States as well as across the globe lose nearly 10,000 scalp hair every day. Though the normal life of a hair strand is around five years, but due to various genetic reasons, men tend to lose their hair at a faster rate as compared to women. As a result, they start growing bald areas on their heads and are unable to replace the lost hair.
Male hair loss is mostly caused due to an increased sensitivity to male sex hormones or androgens in various parts of the scalp. The problem of hair loss is often passed from generations to generations. Let’s go through some of the most common causes of hair loss among males.
Causes of hair loss among males
Hair loss among males occurs due to many factors including hormones, heredity, and age. Some men have areas on their scalp, which are highly sensitive to male sex hormones present in their blood cells. These hormones often cause hair follicles to shrink and eventually affecting their capability to produce and replace lost hair.
If you are a man aged between 20 to 35 years of age, and have been experiencing baldness, you run great chances of undergoing male pattern baldness. This means, a person experiencing male pattern baldness starts losing hair following a typical sequence or pattern. The men show initial symptoms of receding hairline first. Gradually, the hair on top of their head also starts getting thinner, which results in a typical U-shape hairline visible around the back side as well as on the sides of their heads.
Sometimes, hair loss is a genetically predisposed condition, called alopecia, which affects both men as well as women. A recent survey indicates that nearly sixty percent of women suffer from some degree of hair loss. However, heredity plays a crucial role in developing androgenetic alopecia or female-pattern hair loss.
Other factors of hair loss among men
Sometimes, high stress also causes men to lose their hair at a faster rate. However, such balding experience is often temporary in nature. Other than this, trauma accompanied by scarring on head can also lead to permanent damage to hair follicles, which eventually causes baldness among men. Besides, opting for a tight hair style such as a braid, can also cause hair loss among men. When the hair is pulled, it irritates and destroys the hair follicles, which again affects the hair growth among men. Let’s go through some of the most prominent causes of hair loss among people:- Physical stress caused due to surgery, ailment, anemia, quick weight change.
- Emotional stress caused due to mental sickness or a diseased family member.
- Thyroid
- High doses of certain medications including Vitamin A, medicines for treating blood pressure and Gout
- Hormonal causes resulting from pregnancy, use of birth control pills, and menopause
Experiencing hair loss or alopecia can be a traumatic experience for many, but there are various treatment options available for people suffering with it. Besides, you can seek the advice of hair care experts and go through important details provided online to treat hair loss.
source: bigmikes-blog - Causes of male hair loss
