How to set Samsung drive "Jumper" to Master, Slave or Cable Select?
1. Upper 32GB (capacity ≥32GB)
Because some BIOS has 32GB capacity barrier, Jumper setting is different.
There are two cases.
  • Having no 32GB capacity barrier ; General.
  • Having the 32GB capacity barrier.
If you set the jumper with the capacity limitation upper 32GB, the system recognizes the capacity as 32GB whatever the HDD’s capacity.
If your system has the 32GB barrier, you can solve it with using the DiskManager.
Samsung Hard Drive Jumper Setting
2. Under 32GB (capacity < 32GB)
Same as below but the jumper is located in between Power and Data connectors.
3. WA3XXXXA, VG3XXX2A, VG33403A
CSEL is the cable select. It’s only used by a system which supporting the cable selecting function with the exclusive cable. The jumper connector is located on the PCBA. ST is only used in the manufacture.
4. WNR-3XXXXA, WN3XXXXXA, WU3XX3A, STG-XXXXA
CSEL is the cable select. It’s only used by a system which supporting the cable selecting function with the exclusive cable. DXX and DCF are used only in the manufacture.
5. TBR-XXXXXA
BI is only used in the manufacture.
6. PLS-XXXXXA
7. SHD-3121A1, SHD-3122A1, SHD-3171A, SHD-3172A, SHD-3171A1, SHD-3172A1
SHD-3211A, SHD-3212A, SHD-50560A, SHD-30420A, SHD-30280A, SHD-30140A
8. SHD-3121A, SHD-3122A
9. SHD-3161A, SHD-3162A, SHD-3101A
STS and ECC are used only in the manufacture.
source: hddoctor
