Quickstart commands, you have to type this commands on terminal.
ls Commands will displays a list of files in the current working directory, you can see that this command is similar to
dir command in DOS
cd directory change directories
passwd change the password for the current user
file filename display file type of file with name filename
cat textfile throws content of textfile on the screen
pwd display present working directory
exit or logout leave this session
man command read man pages on command
info command read Info pages on command
apropos string search the whatis database for strings
source: mangtatang.dagdigdug.com - Linux basics commands
