Anyone who has never made a mistake has never tried anything new. -- Albert Einstein.
Here are a few mistakes that I made while working at UNIX prompt. Some mistakes caused me a good amount of downtime. Most of these mistakes are from my early days as a UNIX admin.
The file /etc/deluser.conf was configured to remove the home directory (it was done by previous sys admin and it was my first day at work) and mail spool of the user to be removed. I just wanted to remove the user account and I end up deleting everything (note -r was activated via deluser.conf):userdel foo
On Linux killall command kill processes by name (killall httpd). On Solaris it kill all active processes. As root I killed all process, this was our main Oracle db box:killall process-name
I wanted to append a new zone to /var/named/chroot/etc/named.conf file., but end up running:./mkzone example.com > /var/named/chroot/etc/named.conf
I had only one backup copy of my QT project and I just wanted to get a directory called functions. I end up deleting entire backup (note -c switch instead of -x):cd /mnt/bacupusbharddisk
tar -zcvf project.tar.gz functions
I had no backup. Similarly I end up running rsync command and deleted all new files by overwriting files from backup set (now I’ve switched to rsnapshot)rsync -av -delete /dest /src
Again, I had no backup.
I had sym links for my web server docroot (/home/httpd/http was symlinked to /www). I forgot about symlink issue. To save disk space, I ran rm -rf on http directory. Luckily, I had full working backup set.
Accidentally changed the current hostname (I wanted to see current hostname settings) for one of our cluster node. Within minutes I received an alert message on both mobile and email.hostname foo.example.com
I wanted to shutdown VPN interface eth0, but ended up shutting down eth1 while I was logged in via SSH:ifconfig eth1 down
I made changes to sshd_config and changed the ssh port number from 22 to 1022, but failed to update firewall rules. After a quick kernel upgrade, I had rebooted the box. I had to call remote data center tech to reset firewall settings.
I wanted to shutdown my local Fedora desktop system, but I issued halt on remote server (I was logged into remote box via SSH):halt
service httpd stop
Created a wrong DNS CNAME entry in example.com zone file. The end result - a few visitors went to /dev/null:echo 'foo 86400 IN CNAME lb0.example.com' >> example.com && rndc reload
In 2006 ORDB went out of operation. But, I failed to update my Postfix RBL settings. One day ORDB was re-activated and it was returning every IP address queried as being on its blacklist. The end result was a disaster.
All men make mistakes, but only wise men learn from their mistakes -- Winston Churchill.
From all those mistakes I’ve learnt that:
Mistakes are the inevitable, so did you made any mistakes that have caused some sort of downtime? Please add them into the comments below.
source: cyberciti.biz
